Flotten,
If you have a manual transmission, the noise you are hearing could be gear lash in 4th gear. 4th (in the 5 spd) is direct drive so a lot of the gears in there are just freewheelin' doing nothing. It usually only happens at low RPM, 1500-1800. All the BOMBed trucks do it. Don't worry, it's normal.
98. 5 2500 QC LB 4x4 5spd, white. BFG 285x75x16
Cummins 24v w/ TST PowerMAX w/EGT and Boost gauges on A-Pillar. VanAaken CPC. K&N In the factory air box. Stock Injectors, Stock Exhaust (Geno's Muffler Eliminator). Re-routed breather stink tube, 2WD-low kit, SnugTop, JJ Stainless Running boards, Tow Hooks, Bushwacker Street Flares, and a Cup Smoothie.
83,000 miles (1/10/01)
