For those that are interested, here is some pics of H2 hummer wheels and xenon flares I recently installed.
Truck Pictures
I picked up the brand new set of 4 tire/wheels for $600 from a tire dealer in Houston. The tires had about 10 miles total on them. If anyone is interested, PM me and I will give you the place I bought them at. Since I am local to Houston, I picked them up, so I don't know what the shipping would be. I also had the tools to enlarge the center hub.
I used the stock Dodge center caps by cutting off approx. 1" of material from the edge of the center cap with a cutting wheel using a small handheld air tool. I then ground down each lip of the lugnut tab so the cap would correctly snap around each lug nut. I then spray painted the Dodge caps using silver Dupli-Color wheel-coating to match the hummer wheel coating. I had the original steel chrome wheels and caps. The caps fit very tight as they would on the stock steel wheels.
Also, the fender flares are Xenon painted to match.
Carl
Truck Pictures
Carl
