Pictures of gauges installed
winter driving and BHAF
Switches where cup dumper is
Hey guys if you don`t mind could post pictures of your gauges installed? :cool: :cool: :cool: The wife and I would like to see the different combinations:D :D :D Thank you all;) ;) :D
My truck is silver with gray int. so I went with gauges that matched the truck and not the gauges on the dash
Here's mine. I also have a fuel pressure gauge over beside the stereo (not pictured).
Small switch under the tweeter will shut the lights off on the gauges. You can also see the single screw I used to hold the replacement A-pillar on. It is very secure.
I used VDO because they match the factory guages pretty well, I'm waiting for my FP guage along with the new Guageworks column pod... . That'll hold me 'till I get bite by the Bombing critter again... ... ... ;)
CCahill, what are your gauges from top to bottom, and what is the range on each (psi, EGT, etc. ).
You must be pretty stuck on your truck to be out shooting pictures of it when someone just yards away is facing impending doom. Why kind of guy are you anyway?? :D LOL
Vaughn
Vaughn,
Top-Trans temp
Middle-Boost
Bottom-EGT
Way anxious to get the column pod, and the FP guage... been having some bad mileage lately and suspect bad lift pump(?)... .
Bought my truck 1 year ago this thur... got 31K on it now, so it would have to be some MAJOR impending doom to get my skinney butt outa' the seat!!!!:D ;)
Colin
DRR-24V-
Could you post some info on your install? Who makes that pod, what vendor sells it, is that a custom mount, and how did you run your wiring?
Thanks,
Dave
Dave MacArthur-It's a US Gear Pod
They are stocked by D. I. S. (in the links) and was easy to install. All wires, etc run up the left side of the dash the same as the Pillar mounts. It has velcro on the bottom to keep it from moving, etc. If I ever decide to go with the Pillar mounts it would be easy to change. I like it better myself. JMO;) ;) ;)
