I just installed Piers' new turbo and cam plate setup. He said to install the cam plate in the middle and work my way foward. So I figured I would start all the way foward and work my way back. With the plate all the way foward it would pull 48 lbs of boost and the EGT's hit 1500 deg. Not as fast as with the old turbo set up. Good power all the way to the top end. I then slid the plate to where Piers wanted me to start at in the first place and got 42 lbs boost and 1350 deg at 80 MPH. I didn't notice much power loss from the first setting but the EGT'S were lower. No lag at all on the bottom end.
1998 2500 4x4 SLT,BD exhaust brake,BD valve body and Pressure loc.
BD Torque loc,370Injectors,Piers Custom grind cam plate,Sun Coast Torque Converter
ATS Three Piece Exhaust Manifold
Jardine exhaust,Transfer Flow 54 Gal. fuel tank
[This message has been edited by DAVE PEREA (edited 04-06-2001). ]
