I'm not really impressed with the fit of the pillar pods from either manufacturer, the last one I installed had to be modified to get the bottom gauge cup off the dash. ( I drilled & tapped a new hole in the steel A-pillar, slightly higher than the existing hole for the grab handle bolt)
Any of y'all been faced with this problem, or did I just get a truck that had a slightly higher dash?
I did try 3 different pods, they were all the same.
Previous '03's I've done, the owners all chose the steering wheel pod, which I've found is an excellent fit.
