The truck is a 2001 cummins nv5600 dually with 90000 miles. I have a nasty vibration under a heavy load when you lug it. Thick has a new clutch no change, sent off an oil sample from trans nothing alarming there.
So I pulled rear diff cover found some steel shavings and this on the carrier. Is this a bad pinion bearing or loose nut?
Thank you
Thank you
