pipes
another lift pump ????
Bilstein shocks are on!
HI HAS ANYONE GONE TO DUAL STRIGHT PIPES. ALSO HOW DOES IT SOUND AND DOES IT EFFECT THE ENGINE IN ANY WAY. WHO SELLS IT AND WHERE?
1998 24 VALVE. BILSTEIN SHOCKS,HELLWIG LOAD PRO 25,HELLWIG SWAY BAR,AMSOIL EVERYTHING.
I had dual exhaust on my 98. 5, straight piped of course! I loved it... Sounded great. I had 4" from the turbo to a 4" into two 3" collector. From there it went over the axle with dual 3" pipes. To finish it off, I had 4" x 20" chrome tips installed. Here's a pic, hope it works!
BOMBED #ad
<body bgcolor="#FFFFFF">
<font color="#000080" size="2" face="Tahoma">
Evan A. Beck "NW PUNK"
</font></p>
<font color="#800040" size="2" face="Tahoma">
'01 2500HD 4x2 QC, 139" WB, 6-speed, ETH, SLT... yadda yadda yadda... 40,326 miles since 4/26/00!
</font></p>
<font color="#0000FF" size="2" face="Tahoma">
<marquee> #ad
Check out NW PUNK for more info! #ad
</marquee>
</font></p>
[This message has been edited by Evan A. Beck (edited 04-14-2001). ]
I have seen 2 home made dual pipe set ups and 1 that was done at a muffler shop. The difference in sound is not a lot different than a single straight pipe, but you can definetly hear that sucking sound from the turbo when you shift on the manual trannies. There really is no advantage to having dual pipes over a single staight pipe, the turbo is the biggest restriction once the muffler is gone. You should also be careful how you split the single to dual, if it is not done well you could put a restriction in the pipe and hurt flow. i do not know of a dual system for sale for our trucks, I think they are one off type of deals.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
