Engine/Transmission (1994 - 1998) Piston/cylinder clearance 6BT
Hey guys, i'm looking for a little help with some specs for a project i'm building.
Goal HP: 800ish
3500ish RPM
Most likely to run nitrous/water injection
I ordered a set of standard marine pistons (wider bowl), ceramic coated tops, teflon coated skirts. I ordered these from Woodruff diesel, however, i'm having difficulty getting any further specs from them. Josh (the owner) won't return my phone calls or e-mails :rolleyes:
I'm ready to bring my engine block down to the machinist, only thing holding me back is not knowing what cylinder wall clearance to run. I plan to run a standard top ring, "Total seal" second ring, and standard oil rings.
The spec's Josh had supplied me with so far, are as follows:
Main Bearing Bore Diameter w/bearing installed 3. 2715"
Main bearing journal diameter 3. 2660"
main oil clearance main bearing . 0055"
Connecting rod journal diameter 2. 7150"
Oil clearence connecting rod . 003-. 0035
Connecting rod pin bore diameter 1. 5764 Max
Connecting rod bolt torque 40#, 70#, 90# using moly lube
Piston Cylinder bore size 4. 020-4. 0225
Ring Gap
Top RIng . 025 min
2nd Ring . 015 min
Oil control . 015 min
Should i just supply the "Piston cylinder bore size" spec to the machinist and let him figure out the clearance by the piston size? I'd rather supply the "prefered" clearance, as the machine shop is not very familiar with "performance" diesel engines. I'm expecting i'd need to run slightly higher clearance's with my "goals" listed above.
Looking for some help from some of the guru's!!! Thanks guys!
I got a little help from the machinist. I mic'd up the clearances at . 005, and spec is between . 004 and . 007... It was recommended to me to run . 010. The machinist i brought the engine to doesn't do any "performance" builds, only stock, but he made a phone call to someone who is involved with performance engine builds and he also recommended . 010 to leave a little extra expansion room for the higher combustion chamber temperatures.
