piston lift pump pressure ?'s
Feedback on Diesel Care and Performance
Club Cab Back Side Glass
therabbittree
Well I converted my truck to the p pump piston lift pump and installed a autometer ultralite II electric fuel pressure gauge. . it reads 55 psi at idle it draws down to say 50 psi driving it hard. . I rechecked the fittings, and bled the air all out and tried different settings on the needle valve setup to adjust it more. . and still 55 -60 psi. . man thats pretty high... I will have to check it with a mech oil pressure gauge tommarrow. . it runs good and has no leaks so far. . any ideas... ? at least when I swap the p pump it will have a load of fuel pressure its its correct. .
thanks,
Deo
I'm not familiar with the ve's method of regulating pressure but the p-pump has a overflow valve to keep it around 35-40 at 2000rpm. That maybe to much pressure for the ve. Most probobly will say it's way to much :D I think the max recomended is like 14 but some people have been uping that at higher boost levels to 30 or so but only under boost with a boost referenced bypass regulator. I would get one on it.
sorry, just reread you post. your pressure is right for the p-pump. i've really gotta stop trying to do more than one thing at a time. :-laf
thanks,
Deo
I recently read some info on Lift Pump ID and Spec's, this is what I have from memory if I remember correctly! Also I would double check any and all of this. There are two types of Lift Pump for the Distributor Injection Pumps (VE), the Diaphram Lift Pump and the Piston Type Low Flow. For the In-Line Injection Pumps there are both Low Flow and High Flow Piston Type. I believe the Low Flow Piston Lift Pumps look identical but have different part numbers and different Pumping Spring Free Lengths. The VE Low Flow Piston Lift Pump has a shorter Pumping Spring Free Length than the In-Line's Low Flow Piston Type Lift Pump. The Max. pressure at the VE Injection Pump is 10psi and the Min. is 3psi, and that is for either type lift pump. The Inline Inj. Pumps have a different spec. that I did not pay attention to. Hope that helps some...
mummn... I may rig up a regulator or something as the lift pump is gonna stay for th e p pump in the spring... . and ideas on what regulator to use?
making oil by adding diesel from the front seal?...
thanks...
deo
make sure the regulator has a bypass not just the cheap hollys that just plain block off fuel. Summit has a pretty good selection but they are pretty pricey. probobly cheaper to just put the other lift pump back on or get a cheaper electric carburater fuel pump.
Allowed pressure for a VE is 15 psi, no less than 3 at WOT. (2?) I put a piston pump on just before the trip to SOP, 15 psi at idle and 10 at WOT. Sometimes it will get 16 when the engine is cold, but not for long. I have a mechanical gauge on it.
well I pulled the wide spring out and left the small diameter spring in the lift pump . . now its 20 psi at idle and when reved... and it pulls down to 5 psi or so on a hard pull... . so I "fixed" that one for now. This lift pump had the big wide spring holder and two strings in side one small diameter that held the poppets and awide er one. . both were pretty long. .
thanks,
Deo
There is an adjustable overflow valve for the VE injection pumps similar to the P-Pump overflow valve.
I think it's a trade secret though... ... .
You betcha. I think our favorite Californian tried one. Not sure whether or not it worked any good for him. Don't dare ask for his R&D:-laf!
Don't worry, if ya got big injectors, I don't think you'll have to worry about much fuel return;).
Deo, that's good info to know. I know some have mentioned picking up a 2nd gen piston pump (used or junkyard etc), then buying a rebuild kit for the low pressure 6320 piston pump and swapping out the springs or something. I might have to pick me up a 2nd gen style piston pump at my favorite junkyard and give that a try or at least looking inside one.
We are currently discussing this very same topic over in the other Cummins web-site. My point I want to make here is that if you see 5 psi with your current set-up, you'll need to ask yourself a couple of questions;
What lift pump do you have.
What type of fuel system mods have you installed
When and how often do you see 5 psi.
If you see 5 psi or less only when you have your foot to the floor, ask yourself how often do I drive with my foot to the floor to achive 5 psi supply or less. :eek: If it's all the time and everyday then you need to take action. If it's 3% of your drive time, then just chill out and enjoy your truck.
VE Injection Pumps-Low Flow Piston Transfer Pump free length 53. 5mm
(2 7/64)
Inline Pumps-Low Flow Piston Transfer Pump free length 58mm (2 9/32)
