I now have the my #11 TST plate installed as well as the AFC spring kit. From reading the turbo should be capable of making 36psi of boost, I have the 215 stock H. P. , but the best boost that the turbo has created is 32psi and the EGT, before turbo, reaches about 1000 degrees @85 mph. I usually run out of running room due to slow vehicles and then stop signs. I checked the fuel pressure tonight and at idle it is 17 - 18 psi at 2000 to 2200 rpm's the fuel pressure is at 28 psi. Does the fuel pressure sound ok or is the fuel pressure barely in the limits?
96 3/4 CC 5-speed,4x4,
anti-spin,tow,camper,3:54
B&W Turnover Goose Ball GY305r70 on Aluminum
Wheels
Brown MFG Heavy duty Front Bumper and I do mean Heavy Duty
Wheels
