New to this Forum.
I have been trying to determine if my HG is bad or not and looking for some thoughts. Here are my current symptoms. Truck has Heat, Temps are normal around 190ish. But my coolant level in overflow never goes up when hot. My upper radiator hose gets very hard when up to temp and radiator cap has a lot of pressure when I open it and overflows. After truck cools down overnight there is a little pressure under cap when I open and I will hear it bubble a little.
I have replaced radiator cap, thermostat and just eliminated the EGR cooler. Prior to its current state. I had no heat and radiator was about 1 1/2 gallon's low. I added coolant with vent tube open and have burped system many times.
My problem is pressure just seems to keep building in radiator and does not go into overflow. Anyone have ideas or is this a sign HG is bad? Thank you in advance!
