Pod's
Replaced the 18.5 exhaust housing with a 16 cm. Didn't help much
kickdown adjustments
Buy them from PDR! I just bought and installed mine, not only are they matched in pop pressure, they come with the best service/tech help in the industry. I don't work for them, but I work on diesels every day, and I can tell you that across the board your dollars go further at PDR. Then matching thing might seem small, but I have installed "new" and "re-con" injectors many times, and can tell that my POD's from PDR are just flat out better than if I bought them directally from lucas.
Just the ol . 02 cents, BTW, your truck might scare you a bit after installation, I still have yet to totally floor mine :D
Russell
Just as a bit of trivia..... they are matched to within 2 bar or less. They come with the correct washer install kit and are fully warranteed against problems...
Ahhh come on R. E. ' mat the sucker and hang on to the passenger... no one should do this alone, you may black out from the "G's" :D:D:D ;)
Pastor Bob
O. L. O. A. C.
Wacker of the Bush,
I am new to the cult, and might just smoke my membership all at one time if I were to honk on it like that :D On the other hand, going down the last road to work today, one of my co-workers pulled behind me in his gas burner, and although he could have wasted me, it was real cool to see the look on his face when we pulled in and parked :p
BTW folks, 2 Bar +/- is a big deal, cummins/bosch spec is as much as 14 bar over advertised pop pressure which is audiable to the keen ears that people like us first genner's have :-laf
Need to get the 16 housing on my turbo, or upgrade to the PDR HX-35 because with the WH1C, and the 12, the boost comes up too quick, transmission seems to groan a bit :eek:
Later,
Russell, POD inductee :D
