Engine/Transmission (1998.5 - 2002) posi-lock connectors
2nd Gen Non-Engine/Transmission Radiator
Engine/Transmission (1998.5 - 2002) Transmission Heater?/ Cooler
Has anyone here used the posi lock connectors that genos sell? And if so do they work? I usually use solder and heat shrink but I don't have room where I m trying to work. Thanks
I used one when tapping my pump and it seemed to do the trick. It is a good alternative to soldering and shrink tube if you do not have room IMO.
I used a couple when installing 8 gauge positive and ground wiring for the RV battery charge line over 6 years ago. The connectors are under the truck cab along the frame rail and exposed to road splash and no corrosion problems or voltage drop so far.
Bill
I have used a variety of their products/connectors over the years and they are very good. I prefer them over any other.
Posi - Lock products are great..... I've used them on many different RV applications and they have perfomed better than any others. I keep an assortment in the tool box of the truck for emergencies.
