post fuel filter presure gauge tap
More Boost Pressure by Cleaning out the intercooler..
Lift Pump Gasket??
Where is a good spot to tap into the fuel line post filter. I would like to add a guage to watch fiter life and liftpump.
get a banjo bolt with an 1/8 npt hole added from ray t , and replace the bolt coming out of the bottom of your filter housing ... or just add a T- barb in the piece of rubber line in the middle of the line from filter to inj pump .
I just used the test fitting on the side of the injection pump. I used a valve core tool and removed the schrader valve insert and hooked my pressure hose up there.
