Preventative Maintenance Brake Fluid Flush?
4th gen Ram 2500 front suspension
trans help
Even my old '03 has, more or less, the same ABS setup as the newer models and needs the ABS module bled for a truly full-system flush. In the past, I just sucked out the master cylinder, refilled with fresh fluid, drove to an empty road, got it up to speed and braked hard to make the ABS activate. I would do that 5 - 6 times, then power bleed the system at the calipers. So, back to my original question: what scanner/etc is needed to do the complete flush on my '03 model?
