One of our work trucks is a 01 dually with 172k on the clock. I have a post in the 911 section but thought I'd try here, too. They pulled a back hoe a couple hundred miles with the truck yesterday and it ran fine, but when they started it today it was blowing white smoke and had a really bad miss. The miss was more noticable at higher rpms. I checked the codes with the key and got 1693. The weird thing was it didn't show the pECU at all. My 02 says pPCU and pECU before it goes back to showing the milage. Could this indicate a problem? I put my cheap code scanner on it and it says the truck has no codes. I plugged the scanner into my car and it picked up the code for a failed O2 sensor that has been there forever, so I'm pretty sure the scanner is working.
Anyone have any ideas?
