smd said:
Wouldn`t it show up if the dealer scanned the system. From what I`ve read, only the Smarty is traceless, isn`t it?
Edge Juice Attitude, TST, MP-8, Edge EZ, anything that is a "piggy back" devices is untraceable to the computer.
Of the "downloaders" the smarty claims to not leave a foot print when you remove the software from the truck.
BIG DIFFERENCES as far as how you get more fuel into you motor here. They all achieve the same thing, but with different methods.
As far as the EZ being detectable, it's the human you need to trick, not the truck or the computer scanners.
If you leave the velco on the fuses box, or even the glue stuff that velcro will leave behind, that's a sign of a box.
Unhooked pryo wires laying around under the hood would be a sign to me.
If you have tapped or cut wires, that's another sign (2nd gens mainly... )
You have to be cleaver here. If my case, if I wanted to try to stiff the dealer for a blown motor, I would removed the 2 edge boxes, replace my stock filter and purchase an a-piller EGT guage since I'm not going to replace my exhaust manifold. barrow my buddies fuse panel cover (since a too new one may be to obvious) At this point all the dealer will see is modded exhaust and an EGT gauge. NOTHING that would technically ever break a motor...
Ohh and I should wash the truck to geth the soot off the back right side! :-laf
What the EZ is doing is just taking the signal from the Rail pressure sensor, telling the computer the rail is at 15,000 PSI when the ECU is commanding 18,000PSI. Even tho the Rail really does have 18,000PSI. When the computer asks for more, more gets in the rail, but the EZ will only show the computer 18,000 PSI when there really is 22,000psi. More power. (I think I explained that right).
Same ideas with boost. EZ shows the computer 20psi when there really is 25psi. The computer wants 22PSI, but the EZ wants 28PSI, so as it fools the computer the REAL pressure is higher then what it thinks is there. Are we confused yet?
