I want to pull just one of my injectors out this weekend to get the model number off of it so I know what I have in there. I have read several threads on the job and it doesn't seem bad at all. I am planning on using the lug nut method to pop it out.
Question is, if I am just taking one out, will there be enough wiggle room around the pressure and return lines to get it out, or will I have to loosen up the whole pressure line assembly on the pump and other 5 injectors. I know I am not supposed to try and bend the line out of the way since it is so small of a ID and could easily screw it up. Anyone tried pulling just one before?
Also, can I just re-use the copper washer or will it leak? Thanks!!
Hopefully I'll be able to get rid of the "mystery" in my sig this weekend.
