Much needed clarification.....
Ok, here I am to explain stuff and clear the fog. And guys, the sarcasm is better appreciated if you actually supply an answer or suggestion afterwords.
ANyway, moving on. To answer Bill's question about the pupm key, I have never had much luck turning the pump shaft and getting it to stop where I want it to. The key fell off the old pump, and we had to get the old key out anyway. SO, after driving around 2-1/2 hours to get parts at CUmmins, and fighting with those nit-wits
, we finally got back to the house at around 4pm. I got in a bit of a hurry (first mistake). WE had the pump on the housing, all the lines attached (hence, the lack of deisre to take the pump out), and were trying to fit the gear back on the pump shaft with minimal luck. Since the gears are helical cut, we knew the gear wouldnt slide STRAIGHT on (though later experience showed us it was almost srtaight on), someone got the bright idea to turn the engine and try to slide the gear on while turning the cranksshaft (mistake #2). Neither of us thought to double check to make sure the marks were still in time (hurry- it was nearing dark, and I had been at it 6 hours on a 4hr-max job; mistake #3) .
GOt it back together, and it was getting fuel to the injectors, but wouldnt start. Took the oil filler neck and elbow out, and saw the "E" on the pump gear, but no "0" lining up with it. Took front cover back off, and sure enough, they were out of time by 7 or so teeth. WIth some turning of the engine, and slipping the gear on and off several times, we got the "E" and "0" lined back up. PUt it all back, and it fired right up, and he went home.
KDP was protruding about 1/16th of an inch, maybe a thin 1/8", but I couldnt get it to move, tapping on it with a hammer and short punch, hammer & screwdriver, etc. Did tighten the 3 bolts I could get to. FIgured since I didnt have a tab handy, and it wasnt in any IMMEDIATE danger, let it be for the time being. IT WILL need attention soon, though (6mo or less).
Jay- re: injectors. His were about 900psi below stock, which will make a huge drop in MPGs. I had a set popping almost that bad, and getting them cleaned and reset added 4MPG. I was surprised he only gained 2-2. 5MPG, but with the higher popping pressure retarding the dynamic timing, it may have offset the new sticks a little.
Brian- WIth this engine being broken in already (212K), I dont think you will see any improvement as time goes on without changing a few things. But, you woule be wise to wait a tank or two before making any changes.
Daniel
