Okay, I got the truck inside the garage and I am ready to advance the timing.
I count 3 nuts on the timing cover and one the bracket on the other side.
What is the best way to get the top bolt off, that seems to be between the fuel supply line and the pump? What is the best way to get the one on bottom toward the block off?
Any other bolts that I need to undo?
How far should I move it toward the cylinder head, i. e. what "incremenet" ?
Do folks normally loosen up all the fuel lines to make the adjustment easier, or it is just with hands or a pry bar?
Brian
Brian
