pyro gauge and warranty
Fleetguard filters
Power Edge Vs. EZ Vs. VanAaken...
The only thing it will void is you exahaust manifold warranty if it cracks, which is common. and even then, it would depend on where it cracked. But no, they cant void you whole engine warranty becasue of the Thermocouple.
Same Question
I have the same question because I'm planning on adding a set of SPA's near Christmas.
Along with the pre, and post turbo pyro, I'd like a fuel pressure, boost, auto temp, ?. Would any of these cause a hardship with the warrenty on the truck, or engine?
AJB
If you are never going to bomb, you can put it Post turbo, but if you any plans to do boxes, injectors, etc, you should have it Pre turbo since that is the temp that is a concern. Some people have it in both places too. Personally,if i was only going to have one, i would put it Pre turbo regardless. As for the other gauges, they should not have any effect on your warranty.
