PYRO PROBE LENGTH
No BD VB for 2001??????
2002 Dodge
I was looking the parts over for the installition of my Isspro gauges and the pyro probe they sent looks too long. Just by eyeballing it where it will go 2 in. from the turbo it looks like I might have to drill through both sides of the manifold just to keep the end from touching. Just kidding!!
I measured it and it's 2 3/4 long and you can figure 3 in. once you get the brass bushing screwed in. Maybe i'm being parinoid. Any suggestions?
ROGER WATTS
2001 QD. CAB H. O. SIX SPEED CUMMINS 3:54 POSI RED AND SILVER, GENO's STRAIGHT PIPE MOPAR FRNDER EXTENDERS 55 WATT HITCH BACK UP LIGHTS PYRO AND BOOST GAUGES
Before you tighten the the retaining nut, the probe tip is adjustable. In other words, you tap the hole, put in the ferule nut into the manifold, put the bushing in, slide the tip in as deep as you want it and tighten the nut that holds the tip in the ferule nut. The probe doesn't have to go all the way in as you must be thinking. The bushing seals the probe wherever you stop. Once the bushing seats on the tip and is snugged up, it doesn't come apart to easily, so get it where you want it before you tighten everthing down.
2001 ETH DEE 2500, 4. 10 LSD, Towing Package, Electric Brakes, EGT/Boost Gauges
Real Backup Lights
After you drill the hole, slide the probe in till it touches bottom, then back it out a little, about 1/4" , that's where you want it, then tighten down the ferrule. I did pretty much the same as Alan describes, can't get a better description than that !
You want the tip of the thermocouple NO deeper than 50% of the depth of the exhaust runner.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X spray in liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
