it is the connector on the end of the cable that is different we cut the stock one off and replaced with a standard . if i can find it there is a company that specializes in making cables and they make one for this purpose , the frequency is so high that you should not do what i did it is hard to keep proper dimensions on the fittings , you can buy a antenna that has the proper fitting and take it to a communications shop and have them cut the fitting off the stock and a short piece off of the new one and do a splice .
