Kirwin
Plugs with the drain hose
I had the EZ Change Drain Plug on my 97 before the Super Drain plug incident. Works as advertised. Hose is about 8 inchess long and it makes a quick and easy job of changing the oil. It is spring loaded and does have a garden hose style cap that prevents it from loosing your oil even of the spring were to break. My only issue with it was that it threads up into the pan and you don't get that last half cup or so of oil out of the pan unless you remove it from the pan. I liked it especially when on vacation as you can change your oil at a campground without spilling a drop.
To add to what I said above the gasket that Geno's started putting in the Super Plug box after my incident was the same as the stock Dodge (Cummins) sealing washer that is on your stock plug. I have never heard of another one backing out after that change. The problem was the cork gasket that the plug was originally packed with from whomever makes the Super Plug, combined with the way the hole was formed in the oil pan. The Super plug was a first rate product and they stood behind it when I had an issue with it as did Geno's. I've done my own mechanical work since I was twelve years old and I just choose not to risk the same thing happening again.
I'm not trying to discourage anyone from buying and using what you want as a drain plug. Just relating my experience with the Super Plug and the nearly catastrophic consequences of it coming out of the pan so that it doesn't happen to anyone else. All IMHO Ken Irwin
