Buffalo posted this a while back:
"If you look under the turbo, you will find an oil drain tube. It connects to a fitting in the block. Look on the same side of the block & you will find what looks like a freeze plug. That can be pooped out and a fitting, from Cummins, can be installed for an oil bypass drain.
The fitting will have to be modified with a fitting that the drain hose from the bypass can be connected to.
There is a good thread, by one of our members, that created this fitting. He had great pictures & descriptions of how to do this. Do a search. It's worth it.
You may want to check on (bob is the oil guy.com) (bypass filter forum) for more information. "
Joe F. (Buffalo)
I have done the search, but still cannot find the thread about the fitting that was created. Does anyone have a link to this thread?
All I have found is a part number from Cummins for the plug.
Also, in another old post, Robertyoke said "there is a plug in the second hole toward the front of the engine, kinda behind the oil filter. pull the plug and get a second drain fitting from cummins. (or use 3/4 copper pipe it fits good)
-robert"
Is there any particular method that should be used to pull the plug to help prevent foreign particles from falling directly into the pan??
If I can get it out, I think I'll be trying to use some 3/4" copper pipe in the hole (as someone mentioned) with excess JB weld to try to prevent leaks, unless I can find the thread about the plug mentioned above or make me another part that presses in correctly.
Everytime I find a good thread that I think will lead me to the answer, someone jumps in and recommends drilling and tapping the valve cover. Not only would I not want to do this for aesthetics, but my oil system (Puradyn for a full size rig) is not pressurized.
Joe F. (Buffalo)
-robert"
