Just a couple quick questions, as it looks like I'll be spending some quality time with the 1st gen this weekend.
From reading multiple threads, I'm left with an unsettled question. Is it ok to turn up the "power" screw on the VE with stock injectors? Seems like I read that if you do, the shut off solenoid will decide to quit working in short order due to increased fuel back pressure or something?
Installing a M&H M2 fuel pin, 3200 rpm spring, M&H timing spacer, and adjusting the pump... does that raise things to about the 275 hp level? or ?? (note I have an HE351 with factory '06 intake and airbox, AirDog 150 with 1/2" lines, and 4" straight pipe exhaust, full throttle travel)
So the previous owner who lived in CO had to take the truck for an emission inspection every year. A year before I got the truck, he said the shop installed new injectors, and that they might be 40 hp, but he couldn't remember. Is there any way to tell if I have a stock injector replacement or a +40 hp without getting them flowtested?
What is a reasonably safe number to torque stock head bolts to? 125 ft-lbs?
At what power level does the stock Sach clutch become unhappy?
And finally... I'm still confused about the M&H timing spacer. Everything I read seems like more conjecture than fact. Does the spacer add any base timing advance? Or does it keep base timing the same, and simply allow the KSB to advance timing further past ~2500 rpm?
Thanks in advance
--Eric
Thanks in advance
--Eric
