I routed my road draft tube to my downpipe!
I bought my truck w/ 208k on it...
I freaked out the first time I took it for a road trip and it coated the underside and backside of the truck w/ oil mist...
it wasn't so bad if I went to the coin-op and hosed it off every now and then... but lately I've been neglecting it, and another 35k miles of hard driving means a little more blowby I'm sure... and all that oil vapor collects and coats everything, and I end up with drips here and there, and it's just annoying...
finally got fed up w/ it, and went and got some good 3/4" hose at the hose/fastener shop. looks like the hose you see on fuel pumps at the station.
routed it down across the bellhousing and bent a piece of 3/4" round tube, blew a hole in the downpipe, stuck the tube in the pipe at a 45* angle, 45'd the end of the tube inside the downpipe and connected everything up.
used almost a full bottle of Simple Green cleaning up underneath the truck (STILL a fair amount of grease here and there! LOL!)
I've put a couple hundred miles on it at 70-80mph...
ZERO drips under the truck (even driving around town, the road draft tube would put down a drop or two often times)
ZERO oil residue on the tailgate.
obviously it would be ideal to have a motor that didn't have this much blowby, but it's still within cummins spec, and I would imagine that even tight engines would benefit from a pan evac setup... creating a vacuum in the crank case frees up power and promotes better ring seal.
wish i'd done this the day I got it!
Forrest
Forrest
