Rancho RS-9000 Shock Questions
Amsoil ATF
HX40 working great, time to get rid of the HX35
Hi,
I had a set of RS-9000's installed last week and the mechanic thought it would be a good idea to place the adjustment knob facing the rear axle for protection. Plus, he though another wonderful idea would be to throw away the paperwork that came in each box.
Since I can't see the adjustment knob easily, does the knob have a pointer that I might be able to feel? What position is 1? 5? Is 3 straight up? Should the knob be able to turn continuously in any direction, going from position 5 to 1 with a single click?
Thanks.
Hal
#1 - Soft = full counter-clockwise.
#5 - Firm = full clockwise.
All settings are obtained with exactly one revolution of the knob, a quarter revolution between adjacent settings. The knob has four raised pointers spaced 90° apart on its circumference. These pointers are not really necessary. Starting in the full counter-clockwise position you should be able to do four 90° turns clockwise, feeling a detent after each 90° turn. Settings #1 and #5 will have the knob in the same relative position.
[This message has been edited by Thomas (edited 05-16-2001). ]
Hal,
I mounted mine facing the axle for protection and I have no trouble "feeling" the location of the dial. I usually step them back to setting 1, then count the clicks forward to 3 or 4 depending on my load. The shafts tend to freeze after a long period of disuse, so it is a good idea to lube them and rotate them once a month.
Dave
1994 2500HD 4X4 modified for off-road camping
2001 2500 ETH/DEE QC SB 4X4
Fritz's DodgeRam.org
Thanks Thomas and Dave. Regardless of everyone elses opinions, the RS's are a tremendous improvement over the OEM shocks!
Hal
Hal,
Righty tighty, lefty loosey. One click per setting.
98. 5' Emerald Green 24v 2500 Auto/3. 54 4x4 SB QC 285. 75. 16's Bridgestone Dueler A/T's on 16" x 8" Alcoa's under Rancho 9000's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk).
