I have a 2005 Dodge Ram 2500. Which Radio do I need? I have seen both would work. Is that true? If so which would you prefer? Thanks!
Jeff_K said:Both will work, but the RB1 has mapping which is nice. I got the RB1 off ebay. There are usually a few on there in the $700 range.
tomeygun said:Second that, the RB4 sucks with no mapping... . :{
JGann said:Hey guys -- I've been wanting NAV since day 1 -- is the RB1 just plug 'n play? I have the 2005 RBK AM/FM stereo w/CD (standard with the SLT) and would like to upgrade. Is there anything else necessary for the swap other than the RB1? Is there a "how to" for getting access and pulling apart the dash. TIA for the info!
Note this Interesting Link comparing the two from a seller of the RB4 on eBay.
bellyscraper said:It's simple just one screw on the front dash and then pull off, just be carfull of the wires attached to the dash plate. Then remove the four screws holding the radio then unplug and replug your radio in. the instructions are in the box with the reciver. Just be carfull not to scratch your ashtray cover, I covered my ashtray with a towel so I would'nt scratch it.
JGann said:Thanks for the reply. I have one question tho -- Is the removal of the dash plate the same for the 6 speeds as the automatics?
Thanks again.
JGann said:Ok -- I paid top dollar at $1k for the RB1. I don't mind tho -- This was the complete kit and was brand new. Seller has a perfect 100% rating (only 40 tho but dating back a few years) and the auction had a buy it now option so that I could get instant gratification. :-laf
Honestly -- you all gave me the confidence.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7989204105
I'm only wondering about where the GPS antenna goes. Is there a standard spot that's ideal?
Thanks again for the inspiration. This will be my first vehicle w/Nav!
You all Rock!
You all Rock!
testraub said:If the instructions are anything like the one's I got with my Sirius rcvr you should have no problems installing the antenna.
