2nd Gen Non-Engine/Transmission RCD suspension problems.
2nd Gen Non-Engine/Transmission Brakes sticking
anyone have this much problem with RCD suspension company. I bought my lift kit through a local offroad shop almost 3 years later the control arm bushings are going bad have taken them apart a couple times and relubed them and cleaned them but they are bad and squeek and creak really bad just going over lips in the road. myself and the offroad company have emailed and talked to them many times last email from them 3 weeks ago telling me they are having trouble getting part numbers? so at this point options are to if possible get bushings from another source. the rear of the control arms have a encased heim sytle ball joint. any options or help on what you would do. I have also emailed king shocks which are normally good with customer service on getting a bigger diameter shock to run with current set up. but again rcd will not give me the specs on their 6" coils in there kit. :mad:
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-DD3600 TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2:eek: " FTE 6" STACK D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-BOX DT PRO-FAB TRAC BAR, CONV-T STYLE STEERING,BORGENSON BOX AND SHAFT,DUNKS TRACTION BARS, AIR BAGS,17'' KMC BLACK HOSS, 37" TOYO MT'S 6" RCD LONG ARM LIFT. :-laf... THANKS RIP Source Automotive
