Engine/Transmission (1994 - 1998) Ready To Kill My KDP
I have received a jig kit and my buudy and I are going to do the job after the holiday weekend. While assessing the job, my buddy brought up a question that I have never seen asked thru all the KDP discussions. Has anyone ever tried to tap the front cover and use a bolt to come in from the front and fix it that way? Is it because the front cover is so thin? Also while were doing the KDP, I will be changing all hoses, belt, water pump, thermostat and cooling fluid(w/the extended cat cooling fluid), is there anything else I have forgotten? Thank you to all that reply, I not only trust, but rely all your info. Rattle On!!!
Be sure to take note of the belt routing before you remove it. The diagram on the radiator support on some '94-'96 trucks is wrong. Otherwise piece of cake, have fun.
