jmarx82,
Unless there's something wrong with your truck, adjusting the speedometer is a simple 10 minute job for a knowledgeable dealer using a Chrysler DRBIII Scan Tool. Find another dealer!
Adjustment can also be accomplished yourself using some brands of aftermarket power programmers like the HyperTech's
MaxEnergy or their dedicated
Speedometer Calibrator.
If you decide to have a dealer do it using a Chrysler DRBIII, tell them to look for the "Set Pinion Factor" under the "ABS - Miscellaneous" menu.
Whatever way you do it, you'll need to know the tire revolutions per mile to assure the highest speedometer accuracy, although the DRBIII will prompt the operator for the axle type and OEM tire size / brand.
To find the revolutions per mile, check the tire manufacturer's web site, or you can calculate it roughly yourself as follows:
Step 1. Measure the circumference of a tire and multiply that by 3. 1416 (Pi).
Step 2. Take 63,360 (inches per mile) and divide it by the number you got in step 1.
A potentially more accurate way is:
Step 1. Mark the bottom of tire sidewall and road surface with chalk.
Step 2. Drive the truck forward so the tire rotates EXACTLY one revolution, then mark the road surface again.
Step 3. Measure the distance between the two marks.
Step 4. Take 63,360 (inches per mile) and divide it by the number you got in step 3.
Good luck,
John L.
