Actually, Tippin Spotted Cow, I believe you are thinking of an ARB Air-Locker. There are also electric lockers and OX lockers (mechanically controlled with a cable). They, too, are true Lockers, but they function very differently from a Detroit Locker.
All of these function as an open differential until the driver engages them. Then they fully lock both wheels together like a spool using air, electricity, or a manual cable. There is no "in-between" or wheel speed differentiation at all. You will go straight, and nothing but straight. No cornering without tire scrub.
A Detroit Locker is not controlled by the driver. It delivers full torque to both wheels at all times. It will allow one wheel to coast faster than the other (so you can corner) but as soon as both wheels are going the same speed again(straight) it engages and drives both.
It works like a ratchet. If one wheel needs to go faster than the ratchet is turning, the ratchet will just click away and allow it to while still driving the slower wheel. As soon as the coasting wheel slows down to the same speed as the slower wheel, both are receiving equal torque again. In this way, it does offer an "in between". Locked like a spool when going straight, but it allows for different wheel speeds on corners.
Detroits are legendary for their strength and absolute reliability. When they were introduced in Mopar muscle cars, they were called "No-Spin" differentials. There are no air lines, wires, cables, clutches, etc. Just 100% of the engine torque to both wheels at all times. For that reason, they are not very "front axle friendly". They prefer to go in a straight line like any locker or spool and tend to fight the steering wheel when you turn tight.
On the rear, you will learn not to power through corners, or you will scrub and chirp your tires because you did not release the tension driving the outside wheel. And every now and then (for me it was maybe once every 5 or 6 months), just to see if you're paying attention, it might disengage or re-engage with such a "BANG!" that you will swear you just left chunks of steel strewn down the road behind you! Nothing ever breaks from that, though.
Supposedly, if you carry very heavy loads, it is capable of breaking axle shafts if you power too hard through a corner and don't allow it to disengage, I'm told. Something has to give, usually the inside tire which will then try to spin at the same speed as the outer wheel causing tire scrub, but I have heard of guys breaking axle shafts that way, too. But you won't break the Detroit. I never had anything break at all and I could go places in 2wd that my buddies couldn't in 4wd.
A very similar, though not as reputable, locker is the PowerTrax. Click here POWERTRAX BY RICHMOND VIDEO DEMOS to go to their website and watch the Dodge videos and see what a 2wd equipped with a rear locker can do that even a 4x4 with limited slips in both axles cannot do. A very cool demonstration!
These are all very different from "Limited Slip" or "Posi" differentials, which use various clutches, ramps, and other internal gizmos to divide the torque between the two wheels. They cannot give both wheels 100% of the torque like a locker or spool and some work far better than others. Many are prone to clutch pack wear. All will leave you helpless if one wheel is in the air or on a very slick surface. The PowerTrax demo I linked you to above demonstrates how worthless those can be in simple everyday situations. But they are OK (and better than nothing) for front axle use if you cannot afford the $1000 price tag of a selectable (ARB, Electrax, OX) locker for the front. They'll give you @ "3 1/2 wheel drive" when used in conjunction with a rear Detroit Locker, which can help keep you out of trouble in the first place.
My dream setup is a Detroit Locker in the rear and an ARB, Ox, or Electrax Locker in the front. What I will actually be settling for in my Dodge, at least for now, is a PowerTrax locker in the rear and a PowrLock limited slip in the front (mostly because: 1> I already have them and 2> because Detroit does not make a Locker for my 3. 54 gear ratio in my Dana 80 and 3> my best lottery ticket so far has only netted me $7).
Anyway, this is what I think I know about lockers! Hopefully it helps...
