Rear differential cover gasket
03 praises and cusses
head lights shut off while driving
I'm planning on changer the rear dif fluid tomorrow and was wondering how many time the gasket is reusable??? I already changed it twice and I now have 40000 miles on it. If needed do you know where I could get the gasket other than the *******??
Thanks in advance for your help!!
I would think that as long as the gasket isnt crakcked and is still in visibly good shape I dont see why you couldnt use it.
But why are you changing your fluid so often? Know what the handbook says, but I changed mine on my last 2 trucks once every 100,000 miles,with no ill effects. Thats because I tow almost everyday. Just curious.
I've been changing mine per the 15k mile requirement, which means I've removed and replaced the covers with the same gaskets 4 times now. And once I accidentally bent one of the gaskets while cleaning it. :rolleyes:
After removal, wipe them down (CAREFULLY!), then put a light coat of gear oil on them before reassembly.
Ryan
