If you tow close to or above the GVRW often, or in warm weather climates, or in the mountainous highways, then you'll probably want 75-140. I've monitored the differential temperatures with both the stock cover and with a Mag-Hytec and if you tow as I described.....you want a good synthetic 75-140. But if you live where freezing is more common then 75-90 is more what you're after. The capacity is 3.8 quarts so you'll need 4 quarts to get the job done.![]()
