Rear diffirential
Clutch failure
Sold my truck, farewell to TDR
If you tow close to or above the GVRW often, or in warm weather climates, or in the mountainous highways, then you'll probably want 75-140. I've monitored the differential temperatures with both the stock cover and with a Mag-Hytec and if you tow as I described.....you want a good synthetic 75-140. But if you live where freezing is more common then 75-90 is more what you're after. The capacity is 3.8 quarts so you'll need 4 quarts to get the job done. :)
thanks for info Katoom i do live in the mountains and it does get cold but i go down to southern cal. for the winter so maybe i'll try half 75/90 and half 75/140 should end up with 75/115
Maybe a 75w-110 is more what you're after then. I understand Amsoil and Redline are the only two, of the more common oils, who offer that intermediate weight.
