As i mentioned earlier, be careful making any kind of repair/splice/connection that makes the wire stiffer. Solder or splice couplers tend to be that way. That is why i completely replaced the wires from inside the door to the connector. Those methods are only temporary, as i learned, and complete wire replacement is a better fix.
With a special tool, i was able to remove the pins from the connector and solder directly to the old pin body.
i also used a higher strand count wire which is more flexible.
yes, this is a crappy design!!!! it stems mainly from the fact that the bulkhead in the door post is very nearly in line with where the wires go through the door.
If the two pass-through areas were 3 to 4 inches vertically AWAY from each other, there would be mainly twist only and less "pinch" flex.
Realistically, i don't expect even my repair to last for ever, due to the amount of bending these wires go through.
I am glad my original post is helping fellow TDR members. That is the main idea of this forum
Jim
Jim
