@bcbender, that wasn't me that uses as bar oil. That was @GSP7 that said he does that. I know better to use bar oil only in saws. There's no tackifier in the oil which holds it to the bar and chain. That might have been okay 40 yrs ago, but newer saws would go through bars and chains faster. Manually pumped oilier might be okay but not automatic pumps. Worked in repair shop and show some of the horrors of using used oil in saws! But hey, if that's what you want to do with your equipment, your dime!![]()
@GSP7 , Show me one saw manual within the last 40yrs that recommends the use of used motor oil to be used in there saws over bar oil? You're also putting a used oil into the environment that wasn't designed for that. I've worked with saw distributors and saw chainsaws that had run used motor oil through them! Gear oil and even used motor oil contains metals that are toxic to wildlife! If caught using in the way that you are, you could be fined and or jail time! Like I said your choice, your equipment! Doesn't make it the correct thing to be done or even the healthest thing for yourself and the environment, FULL STOP!
I've used Amsoil 75-90 Severe Gear 75-90 every 50K since new. It looks like new. Still amber translucent. Same deal with 75-90 MTG manual trans fluid.I called AAM many years ago about fluid use in the 11.5” axle and they said that it was designed to run 75w-90 at all GCWR’s, but that if one ran at max GCWR thru Death Valley on a regular basis then 75w-140 wouldn’t be a bad idea. So not much benefit to it, in their opinion.
The current 12.0” axle uses 75w-140 in DRW applications, but the GCWR and engine torque are a bit higher than what the 11.5/11.8 ever saw.
Rear differential level?? How far below fill hole should it be?
Thanks
Craig
1/4" ±1/4", so I just go until it leaks out the fill hole.
I don't know if this will start a war but I am ready to change fluid in my dually. Do I use an oil that has additive? Reading on another site I copied this
"(03-001-20 ) and it recommends a complete fluid change of the differential using SAE 75W-85 HD Ram GL-5 Synthetic Axle Lubricant. The sales code for this differential is "DSA".
75w-90 is what was recommended for the D60 and D80, aside from heavy towing which called for 75w-140.And.....this brings me to my question - 75-85W oil is not readily available - have to order from AMAZON. Is using 75-90W or higher okay for the Dana 60 or 80?
Dana axles haven't been used since 2002. Dodge switched to AAM with the 3rd gen and they are still used. The front is an AAM 9.25 and the rear can be an AAM 10.5, 11.5, 11.8, or 12.0. The 2018 in your sig will be a 11.5 if it's a SRW and an 11.8 if it's a DRW.
Long story long, 75w-90 is just fine and what I've used in my '05, '18, and '22. 75w-85 was likely a small attempt at improved fuel economy.
I run 75-90 SG in the front axle and 75-110 SG in the rear on my 15 DRW. Heavier in rear because 1/2 my miles are towing 35k combined plus. I changed the front early on. Not sure if I will do a second change, 4wd has barely been engaged.
