2nd Gen Non-Engine/Transmission Rear End Ring gear and Ratio?????????
Engine/Transmission (1994 - 1998) p-pump throttle linkage
Engine/Transmission (1998.5 - 2002) Bosch 275 Injectors
Have a 2005 Dodge 3/4 ton 4wd 6 sp man... need a new rear differntial...
VIN # 3D7KS28C55G701848
Bar Code on rear axle ... . 3 groups of numbers... . (P) 52104
5 or 6 65AG
(7)X2DH208421319
Need to know,, Ring Gear Size
Gear Ratio
Locking or non locking differnetial
THANKS
Look for a sticker on the inside of the front hood, just to the rear of the hood latch. This gives all options on the truck from the factory, includijng the R&P ratio.
The rear end size is an AAM 11. 5".
Where is reverse located? Up and away, or in and down?
LSD or non shouldn't matter if all you are ordering is a ring and pinion.
I understand that any Dodge dealer can plug your VIN into their computer and read out the details of a late model Ram truck.
This is true. They can also provide complete service history - at least of things a dealer did and check for recalls that haven't been done/have been done.
Give a dealer a call and see if they'll help over the phone. As long as they're not too busy . . .
