reccomendations on a possible engine oil temp sensor?
lock-n-stitch
Question for SBC users
Does any one have any advice on placing an engine oil temp sensor? Should I do it, or not worry about it? It's for a 2002. If so, where should I put it?
2 good locations i can think of...
1- 1/8"npt port on top of the filter head. .
2- in the engine oil pan. . either punch & tap the pan, or find an adapter bushing and plug it where your oil drain plug goes. . i think the plug is m18x1. 5. . you could use a m18 plug and tap it for a 1/8"npt, or get an adapter from m18 to 3/8" npt and bush it down to your temp probe thread size [i can't find a m18 to 1/4" or 1/8" npt, only 3/8" and 1/2" npt... ]
for plug - 18MMOR-PLUG [gates hydraulics part number]
for adapter - 18MM-6FP [gates hydraulics part number m18 to 3/8"nptf]
Put mine in there too.
sean3073 said:
thank you very much. I never thought of looking at the filter for a plug in spot.
Put the Westach probe in the Oilfilter Housing 1/8 Pipe pulg. Works great It reads 190 to 200F.
I did the drain plug thing for the 47RE, Have yet to put the probe in the pan. Moose00
