red fuel
Clearing "Permanent" DEF related codes
onboard air compressor
Do like Japan and flush it out to sea? Or store thousands of tons of tainted material in bags? Or like Russia and make the area around the plant off limits? Or transferring their stores of waste in the arctic to another location?
There’s 250,000 tons of nuclear waste in storage around the world with no way to make it safe. When you figure out what to do with that you can write your own check.
If in emergency you need to run dyed fuel document it well, it takes several tanks to clean the dye out, the test most States/Feds PPM, Parts-Per-Millionth.
The tech a CMEP told me not to use RED under any circumstances as it is lacking essential additives for the Injection System.
