AH64ID
Greetings;
"Remote start disabled." It's -1 this morning.
Disconnected pass. batt neg & read 12.78V.
Disconnected driver battery pos & was 12.76V.
Reconnected batts. Turned on ignit & dash msg "<8 Volts".
When started manually, most truck screen options were greyed out & dash displayed "Battery saver node." Heater fan would cycled hi to low & dash battery screen alternated between 11V & 14V 'bout every 10 sec. Center display returned to normal after driving 15 minutes.
With pass batt neg disconnected, driver batt connected, dash was dead. Thought I could use truck as voltmeter?!? Seems it's not a simple parallel hookup, eh.
How can I measure if one batt is bad?
If one battery is bad you need to replace them both. If those are the OE batteries they have lived longer than average these days, time for a new set.
