Red Line Oil Diesel Enhancer
Hate to ask but...........
what do you guys need?
Hey Guys:
I started using Red Line Oil's diesel fuel enhancer a couple weeks ago at every fill-up. . i have noticed a smoother idle and slightly better fuel milage... have any of you heard anything bad about that stuff. . lemme know via e-mail or on here. . thanks!!
1993. . LE. . 4x2. 5-speed. . white. . 4-inch pipe no muff... K&N air filter. . 138,000 miles. . "The Phantom"
Better idle, huh? It's common to make such observations when you like something you use or you enhanced. Just like I thought that I felt a difference upon removing the silencer ring from the turbo. If you like the Red Line additive, use it. It's good, nothing bad about it. I use the Stanadyne Performance Additive, because it's the best on the market and I buy it in 5 gallon cans at a better price than what I get in the small bottles regardless of brand name. Either way, use it at each fill up, because Diesel fuel has lost a significant amount of its lubricity lately and that is really what you need the additive for.
520 Rear Wheel H. P. and 800+ ft/lbs Torque = 15. 5 sec @ 97 mph with the rear wheels spinning in 5th gear going through the traps in the quarter mile. No slicks here, pal, no fancy auto transmission, just the truck in full street trim, 7400 lbs. of Auto Wurks Diesel/BD Performance raging, fire-breathing DIESEL POWER
DieselB59
Is there a wesite for this stuff?
Sky
2001 QuadCab,SWB,Auto, 4X4,4" Flowmaster Exhaust,... ...
4-Sale 1994 4X4 cummins, Two tone blue and silver, all stock 105k
DieselB59, it's great you feel the Stanadyne product is the best on the market however, others feel the Red Line products are superior. I have been using Red Line's 85+ Diesel fuel conditioner (same formula as their Diesel Fuel Catalyst..... now) since 3k mi. until just recently (I just switched over to the Amsoil Diesel Fuel Concentrate). If the Amsoil product proves its worth I'll continue its use, if not, I will run (not walk) back to Red Line! Personally, I have a problem trusting a company who can't produce a reliable injection pump (i. e. , Stanadyne injection pump in the 6. 5 Detroit/GM TD). #ad
Sky, check out: www.redlineoil.com This link used to be on the Links page however, someone deleted it. Red Line has a very thorough website... check it out... even if you're a diehard ________ customer.
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps, Mag-Hytec diff. cover & trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, VDO Vision gauges, Dynamat, '00 Sport grille & valve cover, '00 Sport headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake and TorqLoc, Prime-Loc, Amsoil Dual Remote Bypass, Optima Yellow Tops, Bosch 275s, VA CPC, (censored), Aeroquip braided s/s fuel lines, Banks 14 cm2 turbine housing/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , BD V10/Cummins hybrid TC & valve body, BD trans. front pump & PressureLoc, Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
[This message has been edited by John (edited 10-12-2000). ]
Well, gotta throw in my two cents worth here. I started using Redline 85+ last winter. My honest evaluation: 1/2 MPG improvement, slightly quieter engine, and solace in the knowledge that I'm lubing my injector pump. When this batch is gone, more will be on the way. Good company, good stuff.
Ron
