The first question you will be asked is "How do you drive the truck?" Highway, Towing, Short Trips? How are you monitoring the regen status? When it's in regen, are you giving it time to complete? Cruzing at highway speeds for a period of time may clean things out.
I am just throwing ideas out there. It kinda strikes a nerve when others have told me to "Search the topic" but search through the forum may yield a plethora of insight. It gets a little tricky with topics that share generations but the Regen topic is fairly focused and widely discussed. I searched a similar concern as we all want to catch anything that may be amiss but if the CEL is clear you are probably fine. Did the 350 mile thing begin as it got cold?
Cheers,
CMB
I drive the truck mixed city and highway. Some towing but infrequent and not heavy. Short trips are rare. Usually 20 plus miles per start. I am monitoring regens with my nose and instantaneous mpg. I cant say I have never interrupted a regen but its rare if i do. And yes this all started as winter temps dropped. But this is Arizona and not that cold. Today high will be 77F and low 48.
Since new my truck has regenerated every 650 miles or so. In the last few months it has regenerated more often. Now it is regenerating every 350 or so miles. Any idea why? Should I be concerned? Thanks.
First question is how do you know it's in regen?
See post 3, my nose.
I would say that's not a 100% certain way to know you're in regen.
How many miles are on the truck? The DPF sensor lines could need cleaned.
Your correct,its not very high tec. The odor is unique at a stop light with outside air coming in. Also the tailpipe is much hotter and mpg drops. At best I would miss a regen using this method. The truck has 31k on it. If the sensor lines are obstructed would the warranty cover it?
At 31K it's doubtful they are plugged and it's more likely you just notice the regens more often right now.
350 miles seems like an average interval between regens, where 650 seems too far for anything less than highway towing.
Man, I have had our 2015 for over 2 year and 37K and have never known when it was regenning!!! Got to get my nose checked. SnoKing
Is there any sort of light or signal letting you know a regen is ongoing?
