You better get your nose checked, or it is not regenning.There may have been a time or two that I smelled something, but not sure, so in nearly four years of ownership I really don't have any idea when a regen is occurring . But 34K on it , I assume all is well.
IMO I wouldn't worry too much about it, no CEL's or warnings, I'd motor on.
The DEF pump wouldn't be pumping after you shut it down. The clicking you hear is likely the exhaust connections etc as they heat cycle from getting so hot during the regen.
My truck seems to like anything from 1500 to 1900 RPM's. But i don't have a monitor that shows DPF regen info.
Just curious if anyone found the preferred hwy RPM that helps these trucks regen? (Either passive or active)
Thx. After 4 years and 35,000 miles, I had to take the truck in for a stationary or forced regen at the dealer. My truck didn't have the most recent RRT update on the ECM (apparently). I am finishing a 2800 miles holiday trip today. Yesterday, I had time to take it slow or drive faster, and while driving, I was wondering if taking a slower road and lugging (not really lugging, but loading it at a lower RPM would generate higher EGT's. Or if that wouldn't crreate enough volume of gas to help regen. I know that lugging a gassed will increase EGT's, but didn't know about these diesels.
Just to be clear running lower rpms is not lugging. Just running lower rpms with a light highway load can increase or decrease EGTs based on load/rpms.
Cummins defines lugging as “Engine "lugging" is defined as operating under a load great enough that engine speed can not increase at wide open throttle (assuming that the governor is not cutting the throttle).”
It can technically happen at any rpm. Cummins also say full throttle below peak torque should be limited to 60 seconds max, and avoided if possible.
