Regen Strategies
Class 7/8 trucks have 5 different regen strategies and the pickup & CC only have 4. Here goes...
Class 7/8:
1. PASSIVE regen occurs when the load applied to the engine allows the DPF to burn the accumulated soot just by working it.
2. ACTIVE regen occurs when DPF is nearing full and you are driving. FYI this is the one makes weird sounds around 900 RPM or so and engine feels like it's fighting for air. BTW... The EGR valve and VGT on the ISX Cummins are really active at this point and make sounds that can only be described as a hiccup, cough, burp, fart and a sneeze all at the same time!!
3. MANUAL regen is driver activated when a switch is pressed and will ONLY begin when it either needs one real soon, or driver noticed that an 'active regen' has already started and then allowed it to continue once truck is parked.
4. FORCED regen is when DPF soot load has de-rated the power and needs to be hooked up to a computer to make it happen (dealer visit $$$).
5. EXPENSIVE!!! The last type is where the dealer will either remove the DPF and hook it up to a machine for cleaning, or replace it... Also $$$$
Pickup trucks & CC models:
1. PASSIVE regen occurs when the load applied to the engine allows the DPF to burn the accumulated soot just by working it. This happens when you tow heavy or "drive it like you stole it". :-laf
2. ACTIVE regen occurs when DPF is nearing full and you are driving. Most of the time, you will never notice this one unless you slow down to come to a stop sight or light while it's going on. . You'll notice a little bit more throttle response at take off, a little more added timing rattle, added smell, slightly elevated idle RPM when stopped or parking for an extended period (stationary de-soot feature added with J-35 flash). My advise when this is happening is to avoid walking close to the tailpipe while wearing shorts!! It will literally curl the hair on your legs!!
3. FORCED regen is when DPF soot load has de-rated power (limp mode + overhead message) and it needs to be hooked up to a computer to make it happen (dealer visit $$$).
4. Is when it goes into limp mode and needs to go to a dealer ASAP and they will either replace it under warranty (hopefully), or make you pay dearly for a replacement $$$!! IMHO this is the time when people come to their senses and delete the junk and become trouble free... Also $$$$ :-laf:-laf
The only one that is missing from the equation here is the MANUAL option!! The one that is initiated by a COMPETENT PERSON when he/she KNOWS that a regen is either desired or dangerous in a particular circumstance #@$%!
I would have considered keeping the junk in place if there was an option to press a button to tell it that I'm 40-50 miles from my destination and it can/should start one now, allow an 'active' one to complete before a shut down, or one that allows John Q. Public farmer to get a regen finished and allows the exhaust system time to cool down BEFORE driving into a dry hay field.
