Relay Mounts?
New Prime-loc style for 24 Valves?
DD 2's kick some A
Has anyone every used the extra relay spots in the relay/fuse box next to the driver side battery. I am wondering if they can easily be used to set up aditional relays for lights etc? I have been eyeing them for a while and am adding two more sets of light so I have an excuse for try it out.
Ted
I have not added relays to my Ram PDC box, but I have obtained several Dakota and minivan versions from the junkyard and built an aux PDC for my truck. You need to find a donor box to get the relay socket pins. Use a small screwdriver to release the lock tab on the back, then use screwdriver to release the lock pin on each relay socket connection and pull the connection out from the back. Reverse the procedure to install the relay socket in your PDC. Note: You will have to disconnect your batteries and disassemble your PDC to install the socket parts.
Dave
