I'm going to have to disagree with a few of you... IF you are cleaning your brass AND using carbide dies you don't have to lube straight side cases. With the lube you are adding a nice dirt attractor unless you clean them again after you have a finished product. Just my opinion after having loaded thousands of 45 APC and 357 Mag cartridges.
Also, lead (wad cutters) is cheap if you're loading light. If you are using the hotter loads you WILL lead the barrel. This was on my . 357 and might not be a problem on a 9mm that doesn't get close to the 1400 FPS of the 357. A 9mm will get in the 1200 FPS pretty easy so watch your barrels to make sure they aren't leading up. They are a PITA to clean!
TJJEEPER,
Yep, Thats right, However, the carbide lasts a lot longer with a light coat of lube. Thats the way I've been doing it for years! The cartridges are wiped after loading as part of a final inspection. You dont have to lube them but I prefer it done that way! Your Choice!
GregH
