Remote dual bypass filter mounts
K&N Filter questions
Decent backup lights
BarryG
Is anyone interested in getting a mount for their dual bypass oil filter. After searching I ran across Ted Kidd's mount. Which seems quite slick with rave reviews from fellow members. I emailed him and tried to get one, however he just sold the last one and said that if I can get four or more people who would like one he would do another run of them. To take a look at his mount go to: www.geocities.com/gypsyted/bypass.htm
If you can't find 4 people, look at my site (below). I have them in stock.
2001 2500 ETH/DEE all Black short bed, Rhino lined, Mag-Hytec rear cover, Amsoil throughout including Amsoil Dual Remote Filter System using RemoteBracket mounting system. Everthing else but leather.
http://sites.netscape.net/remotebracket/homepage
BarryG. . I have the Tedd Kidd mount and like it however the pic that Kollmer shows is very nice also. . did you also see the billet adapter offered by another member? I'll edit with a link in a few min. [HAVE TO LOOK THRU MY LINKS FOR IT. . oops hit cap lock]
edited... sent you pic's via E-mail...
[This message has been edited by willyslover (edited 03-10-2001). ]
WARNING: I went to replace my filterand had the wrong size. With my bracket you can use a BE 90 (rated to 10 quarts I believe), BE 100 (rated to 15?) BUT NOT THE BE 110, IT'S TOO LONG - HITS THE WHEEL WELL!!
Fortunately there was a local amsoil dealer with a filter as the one I took off was punctured - was a headache instead of a really unpleasant situation.
So DON'T CUT MY BRACKET SHORTER IF YOU GET A SHORTER BATTERY!
If you use a bracket that sits on top of the battery ONLY (mine has a side piece as well)you'll need to shim it or use the BE 90 if you get a shorter battery.
http://www.geocities.com/gypsyted/bypass.htm
[This message has been edited by ted kidd (edited 05-04-2001). ]
Hey Ted. . Can I use the longest [BE110] one with the proto bracket I bought from ya. . [it was taller than the current release] ? Gary
