I pulled my edge comp for CA smog test, disconnected the wiring harness, and now have the check engine light on. I pulled the codes and I got the companion code, as well as 0234, overboost. I did some searching and it seems like the MAP sensor could be failing. My question is why would it be OK with the comp hooked up, but be throwing a code when it is disconnected? Any other thoughts on what could be wrong?
